Topic: Audo Output Settings to American Audio DP2 Controller
I only use the controller about 3 or 4 times each year but it's been a while this time. I could not figure out how to configure the outputs on the VDJ software to give me one table on the left and the other on the right. The signal came out of both channels which prevented me from isolating to preview music and beatmatch.
I tried placing the left deck on channels 1 & 2 and the right on 3 & 4 with the Master going to 5 & 6 but nothing seemed to work. I got full signal from both decks out of the left side of the controller.
What am I forgetting?
Posted Tue 29 Oct 24 @ 6:02 am
For Windows, you ll need to install the driver from https://www.adj.com/dp2 (Downloads tab), but not sure if it properly installs on Win 10/11
The Audio setup should be "Master" to chans 1,2 and "Headphones" to chans 3,4, assuming you connect speakers and Headphones to the outputs of the device.
