Topic: Is there a way to make links between songs?
SepatroPRO InfinityMember since 2019
Hello,
Is it possible to add links from one song to one or mother other songs? It could be useful to easily jump from one song to another song that you consider compatible.
Posted Thu 17 Nov 22 @ 8:34 pm
like a reminder "this track follows the other track" ? that what the "sticky" plugin does.
Posted Thu 17 Nov 22 @ 8:43 pm
I didn't know about sticky! Currently using comments for this task.
Ill check it out, thanks.
I hope it doesn't use a custom button, as I've already filled all 4!
Posted Sat 19 Nov 22 @ 10:31 am
You can have more than 4 custom button scripts if you like
This is probably the easiest way:
But you can also get skins that have more, or add them yourself, or simply setup more with script, and have a secondary controller trigger them
Posted Sat 19 Nov 22 @ 1:01 pm
I installed the "sticky" add-on, but - and I realise I am probably missing something extremely straightfoward - where is it? I don"t see anything that changes. How can I invoke the sticky add-on?
Posted Fri 25 Nov 22 @ 2:30 pm
if I remember right it installs as a master fx
Posted Fri 25 Nov 22 @ 2:53 pm
I indeed notice it as a master effect... but also there, after activation, nothing seems to happen...
Posted Fri 25 Nov 22 @ 3:00 pm
try pressing the list button twice,
I've been told a bug crept in while I was offline and I haven't looked at it yet, pressing the list button twice solves it.
Posted Fri 25 Nov 22 @ 3:47 pm
