Topic: having issue with ddj-rzx - there is no outbond sound - Page: 2
Same issue here with the DDJ-RZX for a while. Everytime I start the computer I have to do the procedure as described in the hardware manual (PhantomDeejay's post), otherwise I don't have any sound from the outputs. It's annoying, but I got used to it (but it shouldn't). Waiting quietely till it's been resolved somehow, hoped it would be on the bucketlist of Pioneer to update the driver if that's the one that causes it. Only have the issue with W10, never had with W8 in the past, but unfortunately VDJ 2021 doesn't work well anymore on W8)...
Posted Tue 23 Nov 21 @ 2:35 pm
I get through everything until i get to the part of Select any of your laptop's own audio interface.
Right click on it and select "Use as default recording device" i don’t see that option …
Posted Tue 23 Nov 21 @ 11:44 pm
Are you able to complete the rest steps though ?
Posted Wed 24 Nov 21 @ 10:07 am
Am having problem with my ddj rzx i installed all the drivers needed but no sound from the master and headphones pliz help
Posted Fri 24 Jun 22 @ 6:02 am
Posted Fri 24 Jun 22 @ 9:54 am
Makepure wrote :
Can you pliz send me the firmware update
Taylorpliez@gmail.com
Hello, I will send you the firmware V1.11, this one fixes a lot of issues.
Good luck.
Posted Sat 25 Jun 22 @ 6:05 am
Posted Sun 26 Jun 22 @ 8:08 am
