Forum: Old versions
Topic: Anyone else with poor audio issues?
I have attempted to use version 8 but am having significant sound problems. Whether I play a video or audio only file everything sounds like there is some type of filter on and audio sounds like its in a tin can. Closing VDJ8 and playing exact same files with media player, the files play normal and sound normal. I have looked at all filter settings and don't see anything out of the ordinary. Please help if you have had this issue or know of a fix. Thanks!!
Posted Fri 21 Nov 14 @ 2:27 pm
chiv67PRO InfinityMember since 2014
Hi i have had the same problem.Its as if a flanger or echo has been turned on.The only answer i found was to restart the program
Posted Mon 24 Nov 14 @ 7:50 am
See post #2 here
Atomix staff - PLEASE add this to the FAQ!
Posted Mon 24 Nov 14 @ 9:33 am
