Topic: Will this set work with virtual DJ???
Posted Mon 04 Apr 11 @ 1:47 pm
not sure if it will work with VDJ or not for i never heard of it from anyone, btw why not go for Gemini CDM-3610 or maybe Gemini CDMP-6000? seems far better than the Gemini CD Mix 5.0
As long as you have an soundcard it will work.
Sound card, and time codes, and it should work just fine. Why not wait for the Gemini CDJ-700's. They come in with a built in sound card, according to their website, and they can be used in MIDI mode therefore eliminating the need for an external sound card or time codes.
Hello I have the gemini cdmp 6000 and I was wondering if and how can I hook it up to the virtual dj program being about to use all knobs and scratch effects thank you for your time
