Really odd, my vinyl quality hangs around 0% and bounces up and back and forth to 100%, then periodically skips around to different parts in the song and the quality is pretty bad. I'm totally updated and am using virtualvinyl5 with a maya44 sound card. I have a huge gig Saturday night and can't play like this.
Anyone got any ideas?
Posted Thu 22 Jan 09 @ 2:11 am
what timecoded vinyl are you using???
Posted Thu 22 Jan 09 @ 11:09 am
virtualvinyl5 the red and blue kind
Posted Thu 22 Jan 09 @ 11:55 am
Press auto config...
and try both clear sound off, and the v4 engine.
Do you have two colored circles or waves at the timecode advanced setting view?
you should also register your serial here:
http://www.virtualdj.com/users/edit.html
and get the latest update
Posted Thu 22 Jan 09 @ 12:50 pm
Yeha, tried it tons of times, and no dice, I do have those circles or ovals that show the vinyl. The main issue that botheres me is the song jumping to different parts.
Posted Thu 22 Jan 09 @ 2:59 pm
yeah, thats cause you dont have a good signal...
Try a few things to eliminate
1) Clear Sound off (timecode setting)
2) V4 engine (timecode setting)
3) latency auto (performance setting)
and.. does circles/waves (depends on view), are they TWO colored? and look like a perfect circle or sinus wave?
Posted Thu 22 Jan 09 @ 3:13 pm
Try manually adjust the silencer slider and gain slider in VDJ timecode settings (advanced view) until you get 100% signal playing the timecode straight (no scratching)
Posted Thu 22 Jan 09 @ 4:40 pm
Sweet, I'll do that and report back, thanks for the help so far.
Posted Fri 23 Jan 09 @ 2:54 pm
No dice, the circles look like many different circles/ovals, and are fuzzy. No luck with he different settings and adjusting. I did a gig last night and had tracks jumping all over the song randomly.
Posted Mon 26 Jan 09 @ 1:06 am
Adjust silencer and gain
until perfect CIRCLE.. not oval ;)
and 100% signal
manually adjust in advanced timecode view
Posted Mon 26 Jan 09 @ 2:09 am
The perfect circle doesn't seem attainable, been playing with it the past 20 mins, no luck :( Not sure whats up.
Posted Mon 26 Jan 09 @ 5:08 am
Hum...
Can you give us some more info..
You say you have Numark VV, yet its not registered in your profile (http://www.virtualdj.com/users/edit.html)
Is it the full package? Numark soundcard too?
Is it PC or mac?
Posted Mon 26 Jan 09 @ 5:28 am
Not the full package, just got the program. I bought the Numark VV separately off Ebay. And the Sound card I'm using is a MAYA 44, running it on Windows Vista.
Posted Mon 26 Jan 09 @ 5:31 am
Maya works fine, used by many...
In VDJ performance tab : set latency to AUTO
Choose the maya as a asio soundcard in VDJ soundcard setting
and in timecode advanced view :
- turn on software RIAA (amp)
Possibly adjust the level sliders after that, to adjust for 100% signal
Posted Mon 26 Jan 09 @ 6:22 am
Thanks a ton for the help so far, I got 100% signal, but still far from a perfect circle.
Posted Wed 28 Jan 09 @ 2:33 pm
