I have every thing hooked up right.. MK2,2 TT, Lap top,External Mixer....Is ther way that when I scratch My TVC I can here my records scratching and not here a weired computer noise...When i try mix that all I here...Does that have to do with my settings?
Posted Tue 22 Jan 08 @ 5:57 pm
yeah, you are having a monitoring problem. timecode itself is the weird sound... your TT goes to the soundcard and the soundcard is outputting the TT inout. but for timecode control, the computer only needs to hear the TT. so there is some kind of control panel for your soundcard which probably has an icon in your toolbar. you want to turn the monitor levels off for channels 1 and 2, but leave the inputs at full. that will fix the problem
Posted Tue 22 Jan 08 @ 8:15 pm
Are you using the demo or the Console version as some of those features are available in pro only available at a
discount.
Please check you have configured it like this.
http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
discount.
Posted Wed 23 Jan 08 @ 7:27 am
