Sorry not getting back to ya early, just back from my gig..
ok .. i tried it on my PC system with the connection i give ya (i always use it like that btw) n i puzzled on how u did not get the signal right. Do check ur cable are placed right n not damaged. Check all is inserted correctly.
Below is the screenshot of my system while using the tccd/tc. N my settings. I also always get 100% on mac n pc. Only TCV, sometime the signal drop up n down but it still ok;)
try it, n also what ur system specs?
Hope this helps;)
Good Luck.
Hope this helps;)
Good Luck.
Posted Sat 19 Jan 08 @ 1:04 pm
all it does is just crash and I double checked my connections. One thing is see the connection to the cdj, it is plugged into the control is that right ?
system specks
intel core cpu
2.40ghz
2gb of ram
1tb of hd space
windows xp pro
system specks
intel core cpu
2.40ghz
2gb of ram
1tb of hd space
windows xp pro
Posted Sat 19 Jan 08 @ 1:28 pm
From ur cdj, the audio out (Red n white RCA) to the input of the mk2 (Red n white RCA). From the output of the mk2 (RCA) to ur mixer (line in RCA, do not use phono).. make sure all is in line...u should be ok;) Also try both timecoded this time, consumer n pro.
From ur spec, u should not have any problem.
Posted Sat 19 Jan 08 @ 1:40 pm
finally might have the problem fix tomorrow when I get to the shop and get some cables
Posted Sat 19 Jan 08 @ 3:19 pm
ok. good luck n post the outcome;)
Posted Sat 19 Jan 08 @ 3:23 pm
Ok I got to 100% for a while now every time I open vdj I get error in the asio. I have ticked it in the Hercules control panel.
Also for the time I did get it working only one of the decks works is that because it is only a trial. Also the effects on cdj did not work
Posted Sun 20 Jan 08 @ 10:46 am
Hi Jag,
Whenever B4 u open VDJ, U need to select ASIO in Herc CP first.
Abt the time only a deck werk, well maybe it the trial version.
Abt the CDJ effect won't werk cos u are using timecodes but the other function should werk such as cue n looping etc. If u play as a normal cd u could use the effect. Unless also u have a mixer with effect or efx processor attached on ur unused channel (3 channel mixer). U can use the VDJ effect of course on timecoding;)
Glad u have it to werk n get the signal, i think my job here is done.hehe...
Also remember, the only way to use this software to its full capabilities, is to use the legal VDJ Pro which of course u are entitled to upgrade with a discount.
Hope to see u as a pro user soon;)
Cheers.
Cheers.
Posted Sun 20 Jan 08 @ 12:28 pm
ok thanks might have to wait to get pro cause it is alot money for someone with no job
Posted Sun 20 Jan 08 @ 1:10 pm
lol strange thing is that if I put a tune on deck A and one on deck B the tune on deck b does not work alt all but the tune on deck A I can here on all 3 channels
Posted Sun 20 Jan 08 @ 2:41 pm
the crossfader of the mk2 must be in the centre. that should do the trick :)
Posted Sun 20 Jan 08 @ 2:44 pm
yeh I did that and the only way to pre listen to the next track is on mk2 for some reason
Posted Sun 20 Jan 08 @ 5:19 pm
On the trial, i think u can't pre-listen on external mixer if im not wrong.
Posted Sun 20 Jan 08 @ 10:33 pm
Well I managed to get a copy of vdj of my friend that does not use it anymore he gave up djing now.
But my problem is that when I try and pre listen to the next track it plays over the other tune that is playing live and everyone can hear it :(. what am I doing wrong
Posted Sun 27 Jan 08 @ 2:52 pm
It is not advisable to obtain unauthorised version from a friend n if he is the registered user of VDJ n did not wanna to use his software again, u can't use it as ur own legally. Thanks.
U could obtain the upgrade to pro with a discount.
As for ur problem, Try this setting.
Inputs: Timecodes
Output: External Mixer
SC: Asio driver
Soundcards: Herc mk2 asio
Input channel: Chan 1 & 2 : Right Deck / Chan 3 & 4: Left Deck
output channel: Left deck : Chan 3 & 4 / Right deck : Chan 1 & 2
Crossfader on mk2 set to middle or in setting crossfader is disable.
Inputs: Timecodes
SC: Asio driver
Posted Mon 28 Jan 08 @ 12:55 pm
