Topic: I HAVE A DAC3 AND I HAVE QUESSTIONS???
MY IN AND OUT LOOP( RED LIGHTS) DONT TURN ON I WONDER??? CAN ANYONE TELL ME WHATS THE PROBLEM
Posted Tue 16 Jan 07 @ 8:47 pm
That's because you are using the native built in support for VDJ using the DAC 3. The functionality is completely different between the default mapper and Boggis's mapper.
The DAC 3 is actually made for PCDJ, hence the difference in functionality as well.
P
Yeah, basically, if you buy the full version of Virtual DJ, you can download a plugin (JPBoggis mapper) to give lots more functinality to the DAC.
thanks guys, ok if i want to buy the virtual dj 4, do you guys know where i can get it cheaper or is it better to buy it form virtualdj.com
You can only buy the full version of the program from this website I'm sure.
If you click here, you can go to the purchase page.
Welcome!!!
P
you can aslo buy virtual dj on cd under the name of Numark Cue at most dj shops now :)
make sure it is an offical sealed box copy from a retuable dealer.
