Hi I bought this console cause i saw it used on a demo. The guy used a cd player as his input and was able to use the console to mix it with a mp3 using the other channel. Since getting the system i have upgrade to the new drivers, firmware and VDj 9, but i still can't get no output sound. It show's on the output scope. I'm using a HP p4 2.4ht 1gig ddr, 80 gig hd, dx 9b, winxp pro sp1. I would really appreciate some help on this topic. Because if i missed something or need to set something up, please give some detail on how to get it working. Thank You
Posted Thu 06 May 04 @ 3:56 am
Using the analog signal input on the front. Hear or record the signal.... sorry
Posted Thu 06 May 04 @ 3:59 am
Hello,
I think you should better ask Hercules support why don't the give a better driver for the DJ Console. It seems to be the problem.
Try a record software and you will see that you can record it... but not listen to it !
Posted Thu 06 May 04 @ 7:01 am
robll75
Virtual DJ user Posted Thu 6 May 04 @ 03:59:20 - level 0
robll75
Posted Wed 16 Jun 04 @ 8:01 pm
guy the input only work with a software that support it not VDJ something like wav lab will
Posted Thu 17 Jun 04 @ 1:32 pm
