Topic: I wish to use an external mixer (USB question)
ciskoPRO InfinityMember since 2003
Hi guys
in this time I'm working with the mainboard soundcard (laptop) and with a old PCMCIA for monitoring (headphones).
First....The two soundcard have different sound quality.
Second....The PCMCIA don't work very good but for monitoring don't give me any problem.
I wish to use an external mixer.....
Is there on the consumer market an USB audio adaptator with two line output???
Or I must buy 2 USB Audio adaptator????
I saw the MIXVIBES usb audio adaptator
Is it good????
Do you Know the link to purchase it on another web site....
Best Regards
Francesco
Posted Thu 07 Feb 02 @ 2:01 pm
Yan-XPRO InfinityHonorary memberMember since 2003
I advise you to search for a 2 channels USB soundcard
I think it will bebetter that getting MONO outputs from your soundcard.
Posted Thu 07 Feb 02 @ 5:32 pm
Yan give some links please!!!!! :)
I think like you it's better!!!!
Posted Thu 07 Feb 02 @ 6:27 pm
mixalisPRO InfinityMember since 2003
Look for TELEX USB audio device. Is not easy to have the same sound from two defferents sound cards. I use laptop playing in gigs but a sent out only the usb audio and i use internal sound card for cue.
For TELEX
https://shop.telex.de/seshop/telex/list_a.html
Posted Thu 07 Feb 02 @ 7:00 pm
DJ RickPRO InfinityMember since 2003
I actually use the Telex USB audio device. I have been for several months. The one I have only has one stereo output. The level on that device is just a bit lower than the laptop onboard sound card. I run them both as 2 seperate channels to the mixer. (headphones are plugged into the mixer for cueing) Before this I was running a split mono output from the onboard card. This only gives you one channel of the true stereo, not a full mono. When setting up the Telex sound device, I lower the main sound cards volume by about 15-20% this matches them up very nicely. I do not notice any less sound quality from the usb device. In fact it was a very nice jump up in quality from the old split mono way I was doing it.
good luck!!
Rick
Posted Thu 07 Feb 02 @ 8:23 pm
i have an egosys wamibox, its a 4 output soundcard thats pcmcia, it also has digital and optical in and outs plus even midi in and out
it has drivers for wdm, aiso, directx and mme, works great with my dell inspiron laptop
ill sell you one for $275
reply to me at "infader1@hotmail.com"
Posted Fri 08 Feb 02 @ 7:58 am
I use the usb adapter from mixvibes since 5 months and it works great.
the product is recognized as philips by windows XP
and install without any driver
the doc claims that it can work in 16/24bits up to 96KHz but no tested
Posted Fri 08 Feb 02 @ 9:03 am
