Hi all, ive been a user of the Atomix software ever since it first came out, so long ago i cant remember the name it used to be called
Anyways i see alot of you wondering about laptop, live use, etc and i would like to share the custom solution i have for you all
I have a computer system that fits inside a 12"x"12.5"x3" thick case. It features an Intel Pentium3 866mhz processor with 133mhz bus, Intel 815E chipset so you can support the ultra fast ata100 Harddrives, It has a standard size IDE 16x10x40 Yamaha CDRW drive that burns cd's in undr 5 minutes, 30gig Harddrive, 256megs of pc133 ram, 2 PCI slots for soundcards, Also has 4 USB ports, and 2 Firewire ports and onboard sound and video, not to mention svideo and tv output. This is all the power of a Desktop in a very portable system
You can slip this and a flatscreen monitor into a case about the size of your record bag and have all the power of a desktop in something not much larger than a laptop. Did i mention this cost about half as much as a laptop and gives you twice the power
Heres what i think the ideal price/performance setup is:
intel p3 866mhz processor
256megs pc133 RAM
30gig Ultra100 HD
12x CDRW drive
Floppy Drive
Your cost $900
of course since i build each one custom, you could select for say... a 700mhz celeron, 128megs ram, 20gig Hd, 56x cdrom drive and the case and it would only run you about $600 or less and on the other side of the coin, I could do a system with 80gig Harddrive, 512megs of RAM, 16x cd burner etc
Ive been building computer systems for audio applications for a few years now and im familar with all soundcards, software and anything else you might have questions about,
so i will work with you and build you a custom solution for your needs
This system is great cuz it gives you so many options in soundcards, It has a nice stereo card built into it already but since you have PCI, USB and Firewire slots, you can select anything you want. although i really like the Echo Darla24, stereo inputs and 8 outputs at 24bit, cost $300 and sounds great. Also has latency of 4ms in cubase vst 5.0
And just as a reference for you all, i had a Dell Inspiron800 800mhz p3 laptop last month. It cost me $2200 for the system, plus $350 for a 12x cdburner and another $600 for a VX pocket 4output soundcard. Thats over $3000 for a system that was scoring less that 50% of what mine does on benchmarks.
laptops are great if you want to do spread sheets on the plane, but as musicans i think what we all really want is a system that is easy to transport to a gig, offers great performance and also is a good value
Email me at LiquidSoundDistortion@hotmail.com with any questions and i will help get you setup with a system thats perfect for your needs and budget
Sorry if anyone is upset that i posted this here, but i think its related to this software and also something alot of users would like to know about
256megs pc133 RAM
30gig Ultra100 HD
12x CDRW drive
Floppy Drive
Your cost $900
Posted Fri 06 Apr 01 @ 10:33 am
To all our users,
please ba careful with this mail.
He has asked autorisation but have already posted his mail before an answer. So we don't know if it a serious service.
Besides, WE ARE NOT RESPONSABLE of this message.
But you can try to contact LuiquidSoundDistortion for more informations.
(sorry LiquidSound but I must post this just in case.... As I have said to you please mail the author)
Posted Fri 06 Apr 01 @ 3:10 pm
