Is it possible to create a filter that only selects tracks that contain cuepoints?
Posted Mon 29 Jun 20 @ 9:18 am
no
Posted Mon 29 Jun 20 @ 10:12 am
Here's an example of a workaround using hotcues
1. Append a hotcue button set_cue action with: & browsed_file_color green - when the cue is set, the track will be coloured green.
2. Set a filter of: Color !="green" - only tracks that aren't green (ie those without cues) will be displayed.
HTH
HTH
Posted Tue 30 Jun 20 @ 4:25 am
I like that a lot. but... i want to select tracks that 'previously' had cuepoints set. otherwise i just set "tag editor/Field1' to 'new' "
Posted Tue 30 Jun 20 @ 7:16 am
This has been requested before - some time ago. I think it's a good idea.
I seem to remember also suggesting a 'cue count' number to be displayed as a column in the browser, so you can see at a glance how many cues a track has, and sort them by clicking the top of the column.
Posted Tue 30 Jun 20 @ 11:15 am
yeah, a 'cue count' would be awesome! I would use it as one way to filter my interesting tracks.
Posted Thu 02 Jul 20 @ 8:08 am
my mistake sorry
Posted Sat 11 Jul 20 @ 9:09 am
There's a wish posted here, if you care to add your input.
https://www.virtualdj.com/forums/222954/Wishes_and_new_features/Cuepoints.html
Posted Sat 11 Jul 20 @ 11:46 am
