About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to remove, move or modify posts.
Topic: How : Samples in a bank changing automaticaly
Hi everybody-
Since i can not use milkdrop (for some reason) in vdj 32 bit (latest build) windows 10 (yes i had opened a thread & tried everything you suggested but i still get the flickering of the skin & no milkdrop playing) & easy and interesting on fps shaders are limited (i have about 14 but they get repetitive) i have the folowing question :
I have a lot of video samples with textures -dancers etc for only audio visualization.
If i put them in a sample bank, is there a way to have them rotate after beeing played one after the other automaticaly (like in automix )?
It is distracting to have to do it manually one by one.
Or please fix milkdrop for vdj 32 bit (i know that some people have it working, but on all 3 laptops i have with the latest public build & windows 10 it just doesnt...)
thank you in advance for the answers
Posted Tue 11 Feb 20 @ 12:35 pm
Have you tried the Slideshow plugin selected as VideoAudioOnlyVisualization ?
You can select the folder the Slideshow will load files from and also enable Video option and set the Length to full.
Posted Tue 11 Feb 20 @ 1:10 pm
OMG !
...there is so much still to learn on this masterpiece of software !!!!
thank you very much !
that did it
Posted Tue 11 Feb 20 @ 1:40 pm
