Topic: Reloop RP8000 and XDJ-RX work ok together?
Hi all, hope this is not a silly question....
I've decided to buy a couple of Reloop decks to compliment my XDJ-RX and breathe some life back into my substantial vinyl collection, and was wondering if there are any known issues with using this hardware together before I buy.
I also intend to use them as DVS but not sure if they can be used seamlessly between analogue and timecode, or is a different setup required...
Your input is very welcome!
Cheers, Rob
Posted Fri 17 May 19 @ 10:11 pm
After a little experimentation it would appear that to use the XDJ-RX for DVS is problematic! I am very rusty it seems lol
I have had some success using a Maya44USB+ for timecode duties, in tandem with the XDJ-RX ASIO but its giving me headaches...
For anyone considering a DVS system, make sure you get a controller capable of providing the inputs. I know you can use an analogue mixer but then you lose a lot of digital fun stuff too.
To recap:
The XDJ-RX can play analogue vinyl through decks attached to phono inputs
It cannot play as a DVS without using a separate soundcard
I would strongly recommend getting a 4 channel controller capable of DVS out of the box!!
I am already in love with my new Reloop RP-8000MK2 decks, even though I can't get the midi side of them functional yet...
....suppose I will have to bite the bullet and get a DDJ-1000! :-/
Posted Fri 24 May 19 @ 10:06 pm
