Topic: VDJ Broadcast - DJM 2000 Nexus Mic
Hi all
Could someone let me know if it is possible to use the mic Chan on the Pioneer DJM 2000 Nexus mixer to broadcast through VDJ. I can get a signal through with music but not from the mic.
Thanks for any help offered
Posted Sun 10 Mar 19 @ 8:23 pm
Posted Mon 11 Mar 19 @ 8:55 am
Thanks for the reply and the link - I will have a look at that in a moment hopefully its a solution !
Posted Mon 11 Mar 19 @ 12:34 pm
Waiste not does this so is,but i think.
Posted Mon 11 Mar 19 @ 1:43 pm
Open the Pioneer Utility and see if there is any MIXER OUTPUT USB Channel that can be assigned as REC (OUT). If set, then you can add a "record" line in the Inputs of VirtualDJ Audio Setup to record/broadcast your mix along with the Mic.
See .. http://www.virtualdj.com/manuals/hardware/pioneer/djm850/advanced.html as an example.. Different mixer but just to see what i mean with the above
Posted Mon 11 Mar 19 @ 1:52 pm
