Forum: Old versions
Topic: Numark IDJ3 Configuration settings HELP????
I'm using Virtual DJ 7 recently bought a new laptop 2 weeks ago and installed the software on it. I can get it to work all but
the headphones If say side A is playing and I want to listen to side B. I'm thinking its a setting??? HELP PLEASE
Posted Sun 20 Jan 19 @ 7:47 pm
Well if you specify what your settings are, then perhaps someone can help...
You say you're using VDJ 7 - is that the LE version that came with the IDJ3? Why have you not registered it here?
Posted Sun 20 Jan 19 @ 8:50 pm
