About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: [NEW JAN 2019] Denon Prime 4 standalone controller, leaked. - Page: 3
You need to post in English here (or use the correct forum for your language).
The Prime 4 is a standalone "DJ System". The whole reason behind it is that it does not require a computer to play music.
To the best of my knowledge, at this moment it does not work with any DJ software. There is no need for it to do so, because it works standalone.
Posted Wed 15 May 19 @ 4:26 pm
Thank you very much for the answer, the problem is that engine does not use video, I have mcx8000 that works very well, I'll have to think about whether to change it or not.
Posted Wed 15 May 19 @ 4:42 pm
locodogPRO InfinityModeratorMember since 2013
Posted Wed 15 May 19 @ 4:45 pm
Very few DJ controllers are designed for video. Especially standalone systems.
I think the only current unit (which is not standalone) is the Pioneer DDJ-RZX.
Posted Wed 15 May 19 @ 4:48 pm
Will you be working on the development to be compatible? or do you see it unlikely?
Posted Wed 15 May 19 @ 4:49 pm
I have denon mcx8000 and it works very well, what a pity that prime 4 is not compatible.
Posted Wed 15 May 19 @ 4:54 pm
Atomix staff have already stated that the Prime 4 will be supported in the future, including customizing the screen display.
As usual they don't give ETA and it will most likely be some months away.
Posted Wed 15 May 19 @ 4:55 pm
Thank you very much for your information. You've been very kind.
Posted Wed 15 May 19 @ 5:00 pm
I know vitual dj can never let us down on prime 4 meanwhile vitual dj is second to non in software basis
Posted 7 days ago @ 12:55 pm
Page : [<<] [<]
