Topic: Vdj 8.3 b4592 home problems selecting effects
NicotuxHome userMember since 2014
Hi,
Using default skin i get some stranges issues :
- MASTER EFFECT combo does not show AutoStart folder making plugins impossible to parameter/enable/disable
- Master V.EFFECT/VIDEO EFFECTS combos only show sound effects & sources (even labelled "Master video effects") when decks EFFECT combo show Sound effects with Video effects folder that contains both Overlays & Transform
when using scripts:
"effect_select 'mic'" or "effect_select 'sampler'" work ok
"effect_select" does nothing
"effect_select 0" works as well
"video_fx_select" or "video_fx_select 0" do nothing
"deck master video_fx_select 0" show sound effects and source for audio only
Hopefully this doesn't affect the Pro Full version I use with another account
Posted Wed 17 Oct 18 @ 12:06 am
Ho,
I do not figure out really when the video_fx_select problem appear, it seems plugins related
I was having 1 plugin both in SoundEffect folder and in VideoEffect folder
I don't know how this dll came in both locations but result is strange
strange too it does not affect pro full version which was having the same dlls
(also strange I find the reason just after posting, while searching for days)
Posted Wed 17 Oct 18 @ 1:46 am
Playing with the video effects. Duel screen action is great, but I’m unable to change the video effects to sample other ones, so I can change it for gigs to keep it fresh. Can anyone help plz
Posted Mon 26 Nov 18 @ 3:15 am
