Topic: Sound card recommendation
I am using a Vestax mixer with Numard NDX 800 to control the software. I need to purchase an external sound card to make it all work. Any recommendations?
Posted Tue 16 Oct 18 @ 5:47 pm
cant you use the Numark NDX 800?? It has a sound card built in.
Posted Tue 16 Oct 18 @ 6:00 pm
JasEvinHome userMember since 2018
Hi there!
I would say Numark DJ IO 2 should work great for you!
Posted Tue 16 Oct 18 @ 6:25 pm
I am going to use the NDX to control the software and play CD and the external Vestax mixer to mix the music on the computer and the CD. I need an external sound card to do this.
Posted Tue 16 Oct 18 @ 6:31 pm
Have you found what you were looking for?
Posted Fri 26 Oct 18 @ 5:17 pm
