Topic: TheLightingController (ShowXpress, QuickDmx, SweetLight) ready for VirtualDJ 2018
Posted Fri 21 Sep 18 @ 4:12 pm
Thank you!! Looks like I’m selling the SoundSwitch box and sticking with Show Xpress!!
Posted Mon 24 Sep 18 @ 12:53 pm
What is TheLightingController vs ShowXpress/QuickDmx/SweetLight
Is it 4 combined products, or 3 hardwares and 1 software or...
What is the story?
Posted Mon 24 Sep 18 @ 1:39 pm
Also, what kind of resources does this take up on your laptop? Does it make your CPU spike up by a lot? I would assume if you use this feature, your specs need to be a lot higher than the standard stuff when you're just doing audio or video alone.
Posted Mon 24 Sep 18 @ 4:22 pm
ShowXpress/QuickDmx/SweetLight are all from same developers, called The Lightning Controller.
The DMX software normally would run on a 2nd computer and take no resources on your DJ computer to use.
Posted Mon 24 Sep 18 @ 5:59 pm
Right, but since this runs off VDJ, wouldn't it have to run in the background of your computer that you're using VDJ on?
Posted Tue 25 Sep 18 @ 12:23 pm
Its built into VirtualDJ already. And protocol for sending commands over network. Shouldnt be much noticeable resource wise.
Posted Tue 25 Sep 18 @ 1:12 pm
Can someone send a link to what hardware is needed?
Posted Sat 20 Oct 18 @ 5:26 pm
You can start here. This is just one from Chauvet, You can check other manufacturers.
Posted Sun 21 Oct 18 @ 10:45 pm
the awesomeness just doesn't stop
Great Job once again to the best team ever VDJ !!
Posted Tue 23 Oct 18 @ 4:55 pm
Gents, stay on topic and stop debating about SoundSwitch.
Posted Mon 01 Jul 19 @ 11:19 am
can this be used with an "auto" function where it builds individual light shows per track for you? like I've seen with sound switch?
Posted Thu 22 Aug 19 @ 3:14 am
djmilaPRO InfinityMember since 2008
No ;)
Posted Thu 22 Aug 19 @ 9:39 am
Posted Sat 28 Mar 20 @ 2:55 pm
Does any one know if the dmx interface made by shavay for showxpres is proprietary or will any old one from eBay worck
Posted Tue 02 Jun 20 @ 8:19 pm
