Discussions about VirtualDJ, and about DJing in general
Forum Guidelines
If you need extended support, contact our Support Team.
(*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: Serato's Echo Out FX
Anyone know of a way to mimic Serato's echo out effect?
Is there a VST plugin that sounds similar to Serato's EO effect?
Posted Sun 08 Jul 18 @ 11:55 pm
Posted Mon 09 Jul 18 @ 12:11 am
This may inspire you:
Posted Mon 09 Jul 18 @ 11:05 am
awesome - that works perfectly.
Thx so much
Posted 7 days ago @ 9:32 pm
bagpussPRO InfinityMember since 2003
Isn't post fader the default mode? Strange if not, as this is now the expected behaviour.
Posted 6 days ago @ 1:19 pm
No, as far as I can tell the default is still pre-fader
Posted 6 days ago @ 2:39 pm
bumpePRO InfinityMember since 2011
I tried that on VDJ 2018 and it did not work, can you please post full directions or test with the V2018 please.
Thanks
Posted 5 days ago @ 9:17 am
It works exactly the same in v8.3 (2018) (I've just tested it to be absolutely sure)
Remember that it's all just new v8 builds - v8.3 and v2018 are just marketing names
What may cause it not to work is if you are running a setup with "external mixer" audio settings
In that case VDJ doesn't handle the mixing (mixing is handled externally as the setting suggest), so it can't decide if anything like effects is done post-fader
Some controllers have the "external mixer" mode setting as default
You can easily check it in the audio settings:
Posted 5 days ago @ 10:12 am
