Discussions about VirtualDJ, and about DJing in general
Forum Guidelines
If you need extended support, contact our Support Team.
(*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: VDJ FILTER
Can we adjust the resonance of the standard filter, like the FX bank filter, other than subtle and strong in the settings? I'd like it inbetween. If not, how about in a future update.
Sometimes a slight turn from the center gives a strange effect, not quite as expected. I can't explain it yet but the lad i DJ with noticed it too, when it happened to him, after I'd spent ages failing to explain it. I'm using a Denon MC7000. Any insight appreciated.
Posted 6 days ago @ 8:15 pm
You can add a factor to it to lessen it's impact. Like in this script:
param_multiply 0.22 & param_add 0.4 & filter
You can of course change the values
You can also completely replace it like explained in this video:
Posted 5 days ago @ 6:25 am
locodogPRO InfinityMember since 2013
This is a guess but have you tried typing in a numerical into the setting?, further guess it should be between 0 and 1.0
Posted 5 days ago @ 11:00 am
Thank you. I'll give those a try.
Posted 5 days ago @ 1:04 pm
Yes, this works.
Setting the filter knob at 9 o'clock and going through 0.1, 0.2, 0.3... in the settings and a difference can be heard. I've gone for 0.8, possibly drop it to 0.7.
klausmogensen wrote :
You can of course
In your video you show the on/off parameter as % variable near to 12, how the VDJ default skin handles the filter knob on/off, could this be similar to the strange behaviour i sometimes experience mentioned in my OP. As using a controller with an indent at 12, could I go into the default skin and set this to an exact?
I really appreciate your comments, many thanks.
Posted 5 days ago @ 3:50 pm
