Discussions about VirtualDJ, and about DJing in general
Forum Guidelines
If you need extended support, contact our Support Team.
(*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: [NEW] Reloop Touch controller - VirtualDJ 8 Pro included - Page: 11
allabout wrote :
I was finally able to get the display link driver downloaded (see attached), however, there is still no display showing on the reloop touch. And I don't understand why???
Did you restart Mac after installation ?
BTW, not sure why you already had a different version of Display Link drivers installed. FYI, you should install the driver provided in Reloop website and not some other.
So what happens when you open VirtualDJ ? Does the additional Touch GUI appear on the primary monitor (above main) or not at all ?
If you minimize VDJ, do you get any white window on your primary monitor ?
If you minimize VDJ while running, and goto System Preferences --> Displays, do you see 2 monitors detected, or just one ?
Try this.. When VirtualDJ starts, open VDJ Settings and goto INTERFACE tab. Then switch to another skin (e.g. from 4 decks to 2 decks) and back to the other one. Wait for a minute. Does the Touch Display appear now ?
Posted 6 days ago @ 12:20 pm
Sorry for the fact I thought mac had windows 10 (though its possible ) , i understand now apple mac has its own operating system . But I must say allabout is not very clear in his information . For the rest I should not interfere with technical questions .
Posted 6 days ago @ 9:03 pm
Hi djdad, Thank you for responding back to my email. I have tried everything and I can't get the display to come up on the Reloop Touch. So I don't know what I am doing wrong? I do have a question. Is the display driver or the touch screen skin, what puts the display on the Reloop Touch? Or is it both? The reason I ask is, the Reloop Touch screen skin is in the skin DJ folder under my documents (with all of my other skins), however, when you go under interface in Virtual DJ it doesn't appear there with all of my other skins (which I don't understand why), so I can't click on it to change the skin to the Reloop Touch screen skin. Could that be part of the problem? Normally when I go into to interface, I just choose the skin I want to use, and it changes it on Virtual DJ. So I am not sure why I can't do that with the Reloop Touch Screen skin.
Thanks, Scott
Posted 3 days ago @ 2:39 pm
The Touch skin will not be visible in VDJ Settings-->Interface tab, can't be selected, because its not a "normal" skin. So, its OK that you dont's see it there.
It's not the skin that will "open" the DisplayLink monitor, its the driver. However, the screen will not be opened if VirtualDJ is not running. That's why i advised to check some other things while VDJ is running (minimized)
Can you also reply to my other questions i posted above ?
Posted 3 days ago @ 3:02 pm
Thanks for your quick reply! I will answer your other questions in a little while.
Posted 3 days ago @ 3:32 pm
Did you restart Mac after installation ?-Yes
BTW, not sure why you already had a different version of Display Link drivers installed. FYI, you should install the driver provided in Reloop website and not some other.-I did install the driver that Reloop provided, and not some other. Just to see what would happen, I uninstalled the driver to see if I got that same error message, and I did not. So then I reinstalled the Reloop driver and it installed fine, but still no display on the Reloop.
So what happens when you open VirtualDJ? It just comes up on my computer screen like it normally does. Does the additional Touch GUI appear on the primary monitor (above main) or not at all ?-Not at all
If you minimize VDJ, do you get any white window on your primary monitor ?-No
If you minimize VDJ while running, and goto System Preferences --> Displays, do you see 2 monitors detected, or just one ?-Just one
Try this.. When VirtualDJ starts, open VDJ Settings and goto INTERFACE tab. Then switch to another skin (e.g. from 4 decks to 2 decks) and back to the other one. Wait for a minute. Does the Touch Display appear now ?-I tried that, and nothing happened
Posted 3 days ago @ 9:15 pm
All I know is that you must calibrate the screen , so find out how to do that .
Posted 3 days ago @ 10:46 pm
Thanks OceanBob. Djdad can you please advise how you calibrate the screen?
Posted 3 days ago @ 11:02 pm
I de-installed VirtualDJ to install it on another harddisk in the same computer . I removed all drivers from the Reloop Touch , but trying to install them on another disk it kept saying the drivers were allready installed on the first disk . So I understand its not possible to use the Reloop Touch on another harddisk in the same computer ?
Posted 21 hours ago
I believe it's some kind of copy protection by the (third party) touch screen driver. If you check older posts (page 8), Atomix did say that something would be done about it.
Posted 12 hours ago
Page : [<<] [<]
