Topic: VDJ Optimizer does nothing
Everytime I run the optimizer it only gives me error messages and does not optimize a thing??? Any help with this would be appreciated.
Posted Wed 24 May 17 @ 2:48 am
locodogPRO InfinityModeratorMember since 2013
What os do you have?
Posted Wed 24 May 17 @ 5:41 am
AdionPRO InfinityCTOMember since 2006
And what problems do you have that you need to use this optimizer in the first place?
Posted Wed 24 May 17 @ 5:49 am
operating system is windows.
The reason I run the optimizer is becuase the processes running while I run VDJ always is on the high side & when I load tracks it peaks out the cpu usage
Posted Fri 26 May 17 @ 2:46 am
It's normal for VDJ to consume lots of CPU resources during loading a track.
What CPU to do have?
A multicore CPU will handle this better.
Posted Fri 26 May 17 @ 5:41 am
VDJ RonPRO InfinityMember since 2010
There is a useful setting in the options to reduce the load rate..the setting being called idle.
With older laptops turning off windows updates can help a lot.
If cpu usage is very high then you might get audio/visual problems.
Posted Sat 27 May 17 @ 6:28 am
