i dragged the song and it came up saying error right under it. Also, i don't hear the song playing, which probably explains the error below it. Can anyone help.. Please! I have a 2015 MacBook Air btw.
Posted Wed 22 Mar 17 @ 10:08 pm
If it says error, it is usually because VDJ cannot find the file on your hard drive. Usually because you have moved it or renamed outside of VDJ. Right click track, relocate missing file and then tell VDJ where it is. Then never move any songs unless you are doing it from within VDJ.
Posted Wed 22 Mar 17 @ 10:32 pm
