Topic: Controller Failed to Connect / Device Failed to Connect
Hello everyone I use a DDJ-SX2 using VDJ 8 and everything was working fine and then all of a sudden my DDJ-SX2 is not responding any more to VDJ 8. I check the play back device, I switched it to different ports on the usb drives, I uninstalled and installed back VDJ 8 and nothing worked. So I don't know how to fix this issue. The pc tells me its detected but on VDJ on the settings in Controller tab it says failed to connect. Clicked connect device and rescan and it doesn't work neither. Please help.
Posted Sat 25 Feb 17 @ 6:37 pm
Open the Audio Controls/Settings of Windows and make sure the DDJ-SX2 is not the default playback/record/communication device.
Posted Sun 26 Feb 17 @ 3:17 pm
I accidentally hit the forget device button. Is there a way to undo this? Now VDJ can’t find my iPhone.
Posted Sat 23 Dec 17 @ 4:26 am
see up in the help support there is a ask a question? click on it and see if max or george or one of the crew is on line. this is live people and they also can do remote access and fix it if they deem it need be.
Posted Sun 24 Dec 17 @ 7:18 pm
i have connected reloop rmp 3a with v8 but output sound through palyer isnt coming.
Posted Tue 23 Jan 18 @ 5:38 am
Could you post an image of your audio setup page in VDJ?
Also remember, that you need to buy a license for VDJ to work with controllers after a trial/test period
Posted Tue 23 Jan 18 @ 9:40 am
Check this http://www.virtualdj.com/manuals/hardware/pioneer/ddjsx2/installation.html
Posted Fri 26 Jan 18 @ 3:58 pm
