Topic: Reset Key To Default Value in Script
Does anyone know the trick to creating a custom button for key reset
On the Virtual DJ 8 default 2 decks there is a way to move up and down keys with plus & minus buttons. When you move off key either the plus or minus button will be lit depending if you're higher than key or lower than default key. If you reverse your actions and hit the opposite buttons you can get back in key and notice that neither + or - is lit. In the virutal dj 8 manual on page 11 it says there is an = key and it's not there. Not that I need it. I really want to do this in a script. Only script commands I see are key +1, key -1, etc.
Uh man.. I'm testing as I'm typing this and I found the answer..
key 0
How simple. Well for anyone else who is braindead at the moment, that's how your reset the key to the original track default key.
Posted Sun 15 Jan 17 @ 5:33 am
