Topic: Build 3378 Karaoke problems
Some serious issues playing karaoke files with this build. The graphics timing of the .cdg file within .zip files is out of sync with the audio ,mp3 file in around 70% of the time. Went back to release build and everything was fine again.
Posted Thu 25 Aug 16 @ 7:08 pm
AdionPRO InfinityCTOMember since 2006
I could not find a problem with the karaoke files I have here.
Would it be possible to send me one of the files that shows a sync problem?
Posted Fri 26 Aug 16 @ 8:32 am
I'm having the same issue.
Posted Fri 26 Aug 16 @ 2:48 pm
For me it was happening on any pioneer or phm MP3+g.
Sound choice, sunfly seemed unaffected. Sometimes it would be just out of sync by a few words or a whole sentence
Posted Fri 26 Aug 16 @ 2:53 pm
glenskiPRO InfinityMember since 2011
I am having the same problems with a lot of my karaoke media with the lyrics out of sync with the music...
The culprit is VDJ 8.2 b3378 - this has the karaoke glitch.
I had spoken with Scott Bye about this and also send him a short video of the problem.
In the meantime, I have rolled back to a previous build of VDJ 8.2
Thank you
Glenn
Posted Fri 26 Aug 16 @ 4:42 pm
An actual file to reproduce the problem would be more useful than a video...
Posted Fri 26 Aug 16 @ 5:01 pm
check PM Adion.
Posted Fri 26 Aug 16 @ 7:11 pm
Posted Fri 26 Aug 16 @ 7:21 pm
nope not fixed. still having the issue on SOME tracks with b3386
Posted Thu 01 Sep 16 @ 3:36 am
DJ Max, is it some LG karaokes ?
The one I sent Adion that was out of sync is fixed with 3386.
But I stumbled on 1 LG file that is out of sync. I tried other LG and it was ok.
I sent Adion this out of sync LG file but i came to the conclusion that it was a bad RIP. Hopefully he will look at it and see if it is a bad RIP.
Could you give a list of out of sync files ?
Posted Thu 01 Sep 16 @ 4:42 am
no it was older PHM tracks
Posted Fri 02 Sep 16 @ 6:17 pm
all were fine until these latest builds
Posted Fri 02 Sep 16 @ 6:18 pm
