I try to keep tabs of what songs I play the most but VDJ8 is not marking my songs as played is there a setting to sort this out.
Posted Sun 29 May 16 @ 8:47 am
Hi Steven, there's 2 ways that might help;
1. Add the field Play Count to your browser section(just right click on the header and select it from the drop down menu)
2. Try out the My library Plugin, it's real good.
hope that helps
ray
hope that helps
ray
Posted Sun 29 May 16 @ 9:43 am
Maybe your time in
options/browser/HistoryDelay
is to high...
is to high...
Posted Sun 29 May 16 @ 10:27 am
And it only registers if the deck fader is above a certain point as well.
Posted Sun 29 May 16 @ 10:35 am
Cheers Guys had the fader to low as it was music during the buffet that was not showing.
Posted Mon 30 May 16 @ 3:19 pm
That''s why I prefer using external mode on the MC6000 so the deck faders in the software are independent of the controller.
Posted Mon 30 May 16 @ 3:24 pm
Ideally you should be using your master volume to control speaker output level, and keep your fader(s) all the way up when a track's playing.
Posted Mon 30 May 16 @ 4:46 pm
