Forum: VirtualDJ 8.1 Technical Support
Topic: Loop problem with Pioneer DDJ-SZ
mankanPRO InfinityMember since 2012
Since I update to 8.1 I have problem with loop out on my controller.
It works perfect to create a loop by hit "in and out", but when I whan´t to release the loop with the "out-button on my controller nothing happens.
I need to push the "out-button" in the software to release the loop.
The loopback mode is set to "no".
Any tip to fix this?
Posted Sat 12 Dec 15 @ 3:41 pm
If you look under the 'out' button, you'll see that reloop/exit is activated by using shift.
You could check the mapping in VDJ and modify how the 'out' button works.
Posted Sat 12 Dec 15 @ 3:57 pm
Loop In/Out buttons work now like almost in all the Pioneer gear. When Loop is enabled (Auto or Manual), the Loop In button sets the Jog to LoopIn Wheel mode (you can use the Jog to adjust the Loop In/Entry point) and the Loop Out button sets the Jog to LoopOut Wheel mode (you can use the Jog to adjust the Loop Out/Exit point).
Use the AUTOLOOP or LOOP button to exit the Loop.
Posted Mon 14 Dec 15 @ 7:06 am
mjpdjsHome userMember since 2018
Problem I am having is once I exit the loop it doesn't start the song from the end of the loop, but jumps further in the song. What am I doing wrong? :-(
Posted Fri 08 Jun 18 @ 7:52 pm
You are probably either using loop roll by mistake or have slip mode enabled
Posted Sat 09 Jun 18 @ 6:38 am
