Topic: Hercules Jog Vision
NAWTBOYPRO InfinityMember since 2003
Will this be supported by VDJ7 and 8?
Posted Fri 04 Dec 15 @ 3:41 am
Posted Fri 04 Dec 15 @ 6:23 am
buenas noches , quisiera saber si se puede usar un controlador hercules jogvision con virtual dj 8 . y si asi fuera como hago para configurarlo
Posted Sat 14 Jan 17 @ 3:47 am
A friend has one, works seamlessly on VDJ8, could do with some better default mappings though.
Posted Sat 14 Jan 17 @ 2:01 pm
That's a poor criticism, what aspects need remappimg & why
Posted Sat 14 Jan 17 @ 9:55 pm
Por favor, intente nuestro foro espanol aqui, gracias.
Posted Sat 14 Jan 17 @ 11:20 pm
Can I use the virtual Dj with Hercules Jogvision?
Posted Sun 23 Apr 17 @ 8:31 am
Yes, with VirtualDJ 8.
You will need to purchase a Pro Infinity, Pro subscription or a Plus license
Posted Sun 23 Apr 17 @ 12:48 pm
Thanks so much Senior Staff.
Posted Sun 23 Apr 17 @ 2:08 pm
timvo14ControlleristMember since 2017
I primarly user my Hercule Jogvision at home on my Desktop PC.
I seem to be having issues getting the VDJ 8.0 and my Jogvision to work with PC.
I gotten the Controller for all intents and purposes. Both channels work, jog wheels etc. I just cant seem to figure out how to get my headphones to
work so I can use it to cue tracks in my headphones while the other is playing.
Is there a default settings page for people using Desktop PC as opposed to a laptop.
p.s. I got it to work with the Jogvision as the main sound card out and using the headphone jack on the controller but the audio glitches badly.
I will free mid track and start playing again on both sides. This doesnt happen when I use the sound card on my desktop PC as the main audio output.
Any suggestions would be greatly appreciated.
Posted Sat 30 Sep 17 @ 2:32 am
Hello,
To avoid glitches, I suggest you
1) make sure you use DJControl Jogvision ASIO, not WASAPI
2) check if the size of ASIO buffer you have set is not too small (the default 10ms should be OK, but you can reduce it)
3) plug the USB audio interface far from the USB plug of the mouse, if you can,
4) use a 44.1kHz or 48kHz audio resolution.
And if you are in Windows 7, select a Windows theme which is not aero.
Please precise what you mean as: I will free mid track and start playing again on both sides. This doesnt happen when I use the sound card on my desktop PC as the main audio output.
Posted Mon 02 Oct 17 @ 10:46 am
It will freeze midway through track and then start playing again on both decks.
This doesn't happen when I use the sound card on my desktop PC as the main audio output, it only glitches when I use the Hercules Controller as the main output for sound.
If I plug my power Desktop speakers into my sound card and use sound card config in Virtual DJ, its works fine, no glitches but I can't use my headphones.
I did realize that my sounds card is not 5.1 Surround card.
On my old Hercules RMX using Virtual DJ 6, I recall using a 5.1 Sound Card that I bought for my PC and using the multiple outputs in order to use my headphones.
Is the easy answer to just get a different internal or external sound card?
Posted Mon 02 Oct 17 @ 5:42 pm
