Forum: Old versions
Topic: problems with my vms4.1
Hello
I've bought an American Audio Vms4.1 a few days ago
But I've some troubles with it
I've looked in the faq but didn't found the answer.
I've installed virtual dj on my pc (windows 7)
I've also installed Asio
But when i plug my vms into my pc and open my VDJ
I can't control vdj with my vms
Nothing works I've tried a lot of settings but nothing works
Is this a problem off my vms and should I send it back
Or is this a problem of VDJ
I hope you can help my and if you have some more questions please ask
Kind regards
Stijn
Posted Sat 07 Jan 12 @ 5:18 pm
VukanHome userMember since 2010
i am having the same problem with mine and i just bought it
Posted Thu 22 Mar 12 @ 8:26 pm
Posted Fri 23 Mar 12 @ 6:42 pm
I have an american audio vms4.1 and i have a serious problem. Everytime i put a song to listen to it on my headphones, when i press the cue button vdj synchronizes
both of the songs .. can you please tell me how to fix this cause i have to work the day after tomorrow?
Posted Tue 17 Jun 14 @ 5:56 am
how did u set up the headphones ????????? i cant hear my headphones
Posted Sat 15 Jul 17 @ 3:04 pm
