Forum: Old versions
Topic: Need help with config
Setup: Intel MBP, VDJ7 Pro, Ableton 7, Hercules Control Steel, AKAI APC40
Rewire is configured OK and shows up on a deck as an Aux In.
Tempo lock is good and sound is fine.
What I can't figure out is how to make VDJ ignore the APC so that I can keep using it with Live.
Can anyone help me out with this?
Big thanks!
T
Posted Thu 02 Dec 10 @ 3:33 pm
<Bump> I still need help on this one...
bumpity
Bump
Bumpity. Really can't belive no one has any input on this...
You can bump as much as you want, but if nobody knows a soultion ................
As far as i know, you can only ignore "all" USB devices, but not only one specific.
But i will ask a friend of mine, maybe he knows more.
Geht mit dem akt. Registry Tool 'Disable Builtin Devices' schaltet alle Definitions ab. D.h. Wenn Du einen Controller in VDJ nutzen willst musst Du Definition und Mapper selber schreiben.
Load the Registry Tool ( https://virtualdj.com/addons/2170/Registry_Tool.html ) and "Enable" 'Disable Builtin Devices'.
So if you now use your RMX, you have to create a own Definition and Mapper File to get only your RMX work.
Have a look in our Download Area, maybe there is both.
https://virtualdj.com/addons/controllers.html?category=best&order=default&search=rmx
If yes, put the Definition File into the folder Device and the Mapper File into the Mapper Folder.
After that, only the RMX should be connected with VDJ.
Hope this was, what you are asking for.
